I have an Echo 1 P90 I'm working on making even a better CQB gun. I've got an M95 spring in there which puts it around 310FPS w/ 0.20g. I just ordered a TM EG1000 after trying out my other TM EG1000 in the gun.
That being said, I'm happy with the gearbox EXCEPT for the wire harness. The thing is a cheap clear plastic thing, like here...
Now, I've taken apart the gearbox a good number of times (since it's so easy to work on) and this has resulted in cracks around the three screw points on the wire harness as seen here...
I put a couple of shims to distribute the pressure of the screw as a temporary fix.
My question is whether or not I can find a replacement harness or even an upgraded one? Echo 1 is no longer making the E90, and I'm having trouble finding a replacement.
Occasionally the semi-auto seems to hang up a little bit, and I think it may be because of the cracks at the screw points pushing the wire harness and trigger mechanism away from the trigger bar.
I figured I'd ask you guys since Dom has a tremendous amount of experience with P90s.
