Ok, I have here a KWA SR12. This has been my project gun that last few months and I have finally finished it, other than an ER hop. The hop up bucking I have in it give me 250 ft of accuracy with .36g BBs.
List of upgrades and parts:
Externals:
AIM 3-9x40x Scope w/ lens covers
Madbull Gemtech QD Mock Silencer
Magpul PTS AFG
G&P Sniper Grip
UTG Tactical Bipod
and finally an Allen stock pouch thingy. It just hold bullets (obviously for show)
NOTE: I will also include the original iron sights that came with the gun.
Internals (from barrel to stock):
Madbull black python 509mm 6.03 mm barrel
stock hop up unit
Angel Customs sniper bucking (best I've used so far for this DMR. I will be attempting a Rhop on this barrel, so if it works out i'll update. I'm just hoping the BBs aren't to heavy for it. I don't want to install an ERhop due to the risk of messing the barrel up.
Stock nozzle
Stock cylinder with 1/4" 70D sorbo
Lonex POM ball bearing piston head (bearings were removed due to the gun not being able to cycle all the way because the spring tightened up all the way before it could cycle)
SHS 15 Metal tooth piston with 2 1/4 teeth removed to fix the AoE
SHS M150 spring
Stock gears/bushings (gears have NO shims on them. They were PERFECT OOTB)
Stock Spring Guide w/bearings
Stock Cylinder with the port on it covered.
SHS Red High-Torque Motor
Everything rewired to deans
Stock Trigger contacts
Stock AR latch/ COL
Everything else is stock if not listed.
Ok now to the most important part.... the price. I've dumped >$650 bucks in this darn thing. I now am in need of money. I MIGHT be willing to trade for something of equal value. If it's less value I'll do a trade + cash - vice versa.
I'm asking $400 for this. FIRM. The only way I would go lower is if I sell this gun to you bone stock externally. I would then take $340 FIRM.
I will also throw in a 9.6v 3000 MaH battery (11.1v Lipo Recommended, as the trigger response isn't great, but I currently don't have a mosfet. That's really the only thing needed in this gun to make it "complete") The stock KWA Hi-Cap is included as well.
IF purchased for $400, I will throw in a few Green Label Pmags (6 I think) Some of them are jammed up, and all they need is to be taken apart and unjammed. I just accidentally overfilled a few of them. They are notorious for this. But other than that, they feed perfectly in this gun. I will also throw in a bag of ~1000 .36g bbs.
I will be updating this with other things for sell. I have a TON of spare internals/externals I need to get rid of.
Album of Pics: http://imgur.com/a/rtO8r
