Bulgarian PTW/AEG mishmash rifle
Post by SteevoLS » Sat Mar 03, 2012 7:28 pm
http://www.airsoft2day.com/news/765-all ... oming.html
Split ICS-esque gearbox, but with a QD spring mechanism. Realsteek style trigger, no dry firing, functional bolt release, internal MOSFET, and all while using standard motors, gears, pistons, magazines and so on. This looks like it might be a winner.
Felix
Re: Bulgarian PTW/AEG mishmash rifle
Post by Felix » Sat Mar 03, 2012 7:30 pm
So basically switch out the top part of the GB and youve got your other set up?
Image[/align]
Post by SteevoLS » Sat Mar 03, 2012 7:33 pm
No, it has a QD spring mechanism. No need for multiple cylinders/uppers. The purpose of the split gearbox appears to be to allow you to just crack the receiver open and remove the spring without removing the GB from the lower.
UF_Jester
Post by UF_Jester » Sun Mar 25, 2012 10:12 pm
Umm... Awesome. How much?
Jon The Student
Post by Jon The Student » Sun Mar 25, 2012 10:59 pm
This looks good. Its about time Systema starts to get competition.
Post by SteevoLS » Mon Mar 26, 2012 6:13 am
Price range is supposed to be in the $400-500 range (seems about right), but the estimated release date isn't until March 2013.
2nd Ranger
Post by 2nd Ranger » Mon Mar 26, 2012 12:31 pm
Avenger wrote:AND it looks nice.
hmmm... that's an iffy statement, first of all before I get flamed for pointing out the flaws in this weapon, I do like it and I will probably end up with one.
But before I buy one a few issues need to be adressed:
1) It has body tabs, these are notorious to break and they suck. they need to figure out a way around it like systema did
2) the built in trigger guard, what if I want to change it or wearing gloves and need to remove it to access the trigger?
3) the fugly attempt at the Daniel defense style rail system, it is to short for the barrel length, and is still attached via the delta ring
finally the most deal breaking for me but probably not the mast majority:
4) the ugly ass trade marks, is the lower receiver compatable with after market? If not then will their be an option of a blank receiver like you can get with the PTW's?
if these flaws are fixed I would seriously consider one but until then it's :-\
UF_Jester
Post by UF_Jester » Mon Mar 26, 2012 8:49 pm
I agree with some of that, 2nd Ranger. I don't know that the body tabs will definitely break off. Kwa ones seem to hold up just fine. I do think the integrated trigger guard is unfortunate and the rails look weird. As for the trades, I always say if the externals aren't awesome, paint it.
I am curious about the trigger too. It doesn't so much say that it is based on a real steel trigger as it says that the trigger has a break and a reset. I hope it's not a micro switch. Airsoft systems makes some pretty nice mosfets from what I've heard, so the electrical certainly COULD BE awesome.
Echo1 Operator
Echo1 Rep
Echo1 Rep
Post by Echo1 Operator » Mon Mar 26, 2012 9:32 pm
the integral trigger guard isn't that big of a deal. the rest of the gun looks cheap. bulgaria..really..most people don't even know where bulgaria is. if you want a ptw, buy a ptw. otherwise, get an echo 1.
dftrent12
Post by dftrent12 » Tue Mar 27, 2012 11:02 am
I have to say that while the externals look pretty cheap I would like to think that the internals will be solid making this a winner for me. I like the split gearbox design and the mosfet is a plus. So it looks like a systema but cheaper and better because it uses standard parts.
Is tactical pastel pony
Echo1 Operator
Echo1 Rep
Echo1 Rep
Post by Echo1 Operator » Tue Mar 27, 2012 12:05 pm
So it looks like a Lamborghini but cheaper and better because it uses Pontiac parts.
Post by SteevoLS » Tue Mar 27, 2012 12:17 pm
I think it might be more valid to compare this to a TM recoil rifle, but with a split gearbox. At roughly 1/3rd the cost of a PTW it will certainly sell well enough, but die-hard PTW owners will never convert to a "lesser" platform. Having used and worked on PTWs a fair bit recently, I can safely say all they offer over a high end AEG is the sound and trigger pull. The hopup is pretty bad for what it is, and the receivers are laughably flimsy.
The only noticeable difference when shooting this rifle (vs. a normal AEG) should be in the feel of the trigger. It still won't sound like a PTW since it's essentially a V2 gearbox with some significant structural and electrical changes.
UF_Jester
Post by UF_Jester » Wed Mar 28, 2012 2:42 pm
I wish they would just sell the trigger as a drop-in part for ICS. That would just about sum up this rifle.
Team United Front CO
Vet:
OP24-Two________________OP Blackout
OP Phantom Hawk_________OP Anaconda
TDC (Ga/SC#1)___________OP Just Cause
OP Irene IX TFR 3-1___OP Ranch Hand-Vietcong CO
_____________________OP SoCo (Ga/SC#2)
Carpe noctem
Proprium nocte
unitedfrontairsoft.com
Post by SteevoLS » Wed Mar 28, 2012 2:51 pm
Not really. This has a thin buffer tube similar to the aftermarket PTW tubes, internal MOSFET, new hopup chamber, and a quick change spring system.
dftrent12
Post by dftrent12 » Wed Mar 28, 2012 7:02 pm
Echo1 Operator wrote:Image
Ok, that was good.
