KWA m4 shooting
KWA m4 shooting
My KWA seems to be pulling to the right with almost every shot, shooting the right distance, hop up working, still going to the right... I havent taken apart the barrel or anything. I have cleaned it once and turned the hop up all the way off, so I don't know what it is. Thanks
"Accept the challenges so you can feel the exhilaration of victory" - Patton
Re: KWA m4 shooting
Your hopup nub and/or bucking are probably not aligned properly with the hopup window on the barrel.
Re: KWA m4 shooting
http://www.southcarolinaairsoft.com/forums/http://www.southcarolinaairsoft.com/newforums/viewtopic.php?t=1
^See my post in this thread, it is the second to last one. It applies verbatim to your issue
Re: KWA m4 shooting
ok now I can't even get the inner barrel out of the gun. It is stuck I assume. It won't slide or budge or do anything. I can't see anything holding it back. HELP!!!!
Re: KWA m4 shooting
Separate the upper receiver from the lower. Gently apply force to the hopup (away from the business end obviously) until it pops out. Sometimes the first time you pull a hop unit out, it's stubborn.
Re: KWA m4 shooting
I have yet to get the stupid thing out. It's almost like its glued. I have applied as much force as possible and it will not come out. I separated it from the lower receiver. It will NOT come out. What the ....?
Re: KWA m4 shooting
Someone help me PLEASE!!!
Re: KWA m4 shooting
Have you looked at some tutorial vids? What have you done so far? (This will help us know what you didn't do)
Re: KWA m4 shooting
I have separated the lower from the upper receiver, tried just pulling it out with my fingers it will not budge at all. And I can't find anyone who has this problem. They all slide out easy.
Re: KWA m4 shooting
What are you pulling on?
Re: KWA m4 shooting
the hop up I guess, the top of it
Re: KWA m4 shooting
Well, not really much anyone can do without seeing it I guess. I'm sure plenty of people won't mind looking at it, myself included.
