Redfox
Address: 1348 State Road S-42-195
Woodruff, SC 29388
Directions: http://www.redfoxgames.com/directions.html[/align]
The field owner REQUIRES all players to wear FULL SEAL eye protection, period. DO NOT attempt to wear shooting glasses or any other form of eye protection that is not fully sealed around all seams at this field. Full seal mesh is OK.
Date:
Saturday, May 20th
Price:
$20
Itinerary:
0800: Registration and chrono opens
0915: Briefing begins
0945: Game begins
1230: Lunch break
1330: Game resumes
18:00 Game ends
Scenario:
Multiple short scenarios on different fields, fast paced and objective based.
Rules:
-No medic heals inside buildings/mostly enclosed structures
-Heal by tying bandage (provided) around upper arm, max two consecutive heals, all friendlies are medics
-Deadrags required to play (Available for $1 at game)
-I highly recommend bringing a sidearm with no MED so you can clear fortifications/buildings
-The field owner does not allow players to carry disposable water containers into the play area
Map:
Important Reminders:
-You need to be IN LINE for Chrono and Registration BEFORE 0900. That means you need to show up at 0800, or 0830 at the very latest.
