Classic Army B&T Proline Mk5 A5
Low Profile Top Rail Mount
Birdcage Style Flash Hider
Stock Internals
Dean's Connectors
341 fps at 20 rps with a 9.6v 2000mah
Classic Army B&T Proline Mk5 K
Stock Internals
Dean's Connectors
325 fps at 18 rps with an 8.4v 1200mah
Echo 1 MK5A4 Master Series
"Black" Gearbox/Motor/Lower Receiver (Installed Systema M100S)
"Red" Gearbox/Motor/Lower Receiver
Guarder Ergonomic Vertical Tactical Foregrip
UTG Xenon Tactical Flashlight
Leapers 40mm Red/Green Dot Scope
Dean's Connectors
"Red" Gearbox - 435 fps at 14 rps with a 9.6v 2000mah
"Black" Gearbox - 336 fps at 18 rps with a 9.6v 2000mah
WE High CAPA 5.1 Dark Dragon with K Split Slide
SOCOM Gear M1911 Desert Warrior
On the Left: "Pride" - G&G UMG .45 Suppressed
On the Right: "Glory" - Cybergun UMP .45 Suppressed
G&G 6.04 TBB through the Suppressor
Dean's Connectors
338 fps at 22 rps with a 9.6v 2000mah
"Glory" Cybergun UMP .45 Suppressed
Madbull 6.03 TBB through the Suppressor
Systema Cylinder & Piston Set
Systema Turbo Gears
Systema Turbo Motor
Dean's Connectors
332 fps at 30 rps with a 9.6v 2000mah
UTG M3S 3 Barrel Shotgun
Echo 1 M249 SAW
G&P M249 Full Stock
Systema Cylinder, Cylinder Head, & Nozzle
Systema PolyCarb Piston & Piston Head
Systema Tappet Plate
G&G M60 Style Flash Hider
Dean's Connectors
G&P Dummy Linked 5.56 Rounds
371 fps at 22 rps with a 9.6v 3600mah
A&K M60 Mk. 43 Mod 0 (Stock)
A&K Duckbill Style Flash Hider
Real Steel Linked 7.62 Rounds (No Powder & Spent Primers)
Dean's Connectors
352 fps at 20 rps with a 9.6v 3600mah (I had the plug in, to bypass the rof controller.)
G&G SOC 16
Dean's Connectors
Stock Internals
344 fps at 18 rps with a 9.6v 2000mah
G&G RK-57
Dean's Connectors
362 fps at 19 rps with a 9.6v 2000mah
Even though the Handguard, Grip, and Stock are made of oak, I did not like the unfinished look of it. After sanding and cleaning, I stained and clear-coated them all. The pictures do not do it justice. It is a much richer red in person.
Cybergun Thompson M1A1
Stock Internals
Dean's Connectors
334 fps at 16 rps with a 9.6v 2000mah
Custom G&G GR-16 CQB-S
Full Systema Super High Speed Internals and Motor
G&G 6.04 TBB with G&G Hop-Up & Bucking
Classic Army Crane Stock (New Version)
DBoys Custom Trigger Guard
552 EOTech Clone Red/Green Dot Scope w/ Foldable Cover
Dean's Connectors
327 fps at 32 rps with a 9.6v 3600 mah
Custom KWA M16
Madbull m120
Systema Torque-Up Gears
SRC High Torque Motor
Prometheus Bucking
Madbull 6.03 TBB
G&G Full Stock
G&G M16 RIS
Real Steel Grip Pod Systems Grip Pod
AMP Special Force Combat Red/Green ACOG Replica
Mad Bull JP Style Flash Hider
Ergo Grip
Dean's Connectors
467 fps at 19 rps with a 9.6v 3600mah
I hope you all enjoyed the updates and better pictures! If you have any questions, please feel free to ask!
