Another gSSun, another problem
Villid
So I was working on my JG 416 gearbox today, and when i reassembled it, the physical safety engages at semi-auto. Anythign ive done to adjust it isnt working. any suggestions?
Re: Another gSSun, another problem
It's likely you've put the physical safety in upside down, if you had to remove it. If that's not the case, then wires could be in the way, causing it to not move correctly.
[/align]-
Villid
Wires may be the cause. When I hooked it up the gearbox wouldnt turn. Blew my fuse. Not sure why it's seized up.
Got the gearbox to turn finally, and the fire selector started working correctly. No idea, but im gonna run with it.
Villid
New issue. With the motor plate installed, and the height screw all the way out, the motor is seating too high and won't turn. If I position it with my hand it turns fine. Are motor plates specific to the grips?
Probably the wires bunching up in the grip pushing it to far into the GB when you have the motor mount/plate installed
OP: Phantom Hawk
SGC
OP: Vietnam Patrol
OP: Decisive Force
OP: Phantom Hawk
SGC
OP: Vietnam Patrol
OP: Decisive Force
Villid
So i found a "minor issue" with my wiring.
This is what happens when you reassemble your gearbox at 2am.
TokenTech89
Don't worry bro. I did the same thing and shocked myself
ibeezthecapn
see, what had happened was....TokenTech89 wrote:Don't worry bro. I did the same thing and shocked myself
what you need there is a bread tie. plain and simple.
AEA airsofter, Anywhere Everywhere Anytime
Last Game OP Vietnam Patrol - US CO - Win
THANK YOU!!
THANK YOU!!
