Is this a perfect fit for anyone that has used an Aug before?
thinking about a long range bullpup
V3 Gearbox swap G36 to aug
TokenTech89
Re: V3 Gearbox swap G36 to aug
The triggers are different and will need to be swapped out. The air nozzles *may* be the same length, but you should double check. Other than that, they should be fine.
[/align]-
TokenTech89
G36 trigger style, or ak trigger style. based on videos they look closer to g36. haven't did a breakdown of mine yet
The trigger styles are 100% different. You would have to open up the gearbox to swap them out if you wanted to pull it out of your G36 and put one into the AUG.
