JG m16A3 problems!?!
Coopraider
First the wiring to the motor need to be replaced wont stop shooting full auto unless you put it on safe. Second mags will not sit in the magwell and feed (think part of the gearbix is messi g it up) if you can help me please send me a message so we can meet up will pay at least 30 bucks to get fixxed more if need be
Re: JG m16A3 problems!?!
That first issue is almost certainly the contact slide being stuck forward for one reason or another. Who told you it was the wires that lead to the motor themselves?
What mags are you using? Give us some details about the feeding issues so we can help. Like I said in the section rules, if you want quality help, give people enough details that they can actually assist. Saying "will not sit in the magwell and feed" doesnt really give us anything to go on. When you cycle the gearbox, is the air nozzle moving back and forth in the hopup chamber? If you don't know what those parts are, see this: http://www.youtube.com/watch?v=YrcrE1Q53oE
Click the link in my sig if you want me to repair it for you.
Coopraider
M step dad told me told me it was the wiring Nd i use king arms mags and havent had any problem with them before i will almost fall out of the magwell Also it seems like the mag release isnt catchimg cause the mag wont go all the way into the magwell
Coopraider
I have Worked with v2 gearbixes and i know how they work but i just want some ody who knows what they are doing to fix it because i have had bad experences with battleca, their tech is good but price is outragious
Well, if what your step dad meant was that it was an electrical issue somewhere in the circuit, he was right; if he meant it was literally the wires that run to the motor, he is incorrect.
You may have to slightly modify the mags and/or mag catch to make them sit properly, I can further advise if I see them and try it for myself. It may require some dremeling and/or shimming of the magwell. This is something I can also fix, via the link in my sig. If you have me repair the issue in your gearbox, and the magwell/mag issues require only dremeling or shimming as I think it will, I will fix the mag/magwell issue for no extra charge.
Coopraider
Thamks dom is any time good for you and would it be done before oP.24 4
Yes, and yes.
Coopraider
Ight thanks i will tryto bring it to you friday After i get home from school
