AGM MK96 spacer
AGM MK96 spacer
Hey all so i recently got a an AGM MK96. Well to start off is shoots great! However the spacer inside the barrel slides around T.T from this it means that the barrel is always in a different position depending on where the spacer is in the barrel. So anyone have any tips to get it back in one spot so it will stop curriving in random directions at random times?
OP: Phantom Hawk
SGC
OP: Vietnam Patrol
OP: Decisive Force
OP: Phantom Hawk
SGC
OP: Vietnam Patrol
OP: Decisive Force
Re: AGM MK96 spacer
Add teflon tape around the spacer(s) to make it a tight fit inside the outer barrel.
Re: AGM MK96 spacer
Alright any suggestions for getting the spacer out of the barrel past the threading?
OP: Phantom Hawk
SGC
OP: Vietnam Patrol
OP: Decisive Force
OP: Phantom Hawk
SGC
OP: Vietnam Patrol
OP: Decisive Force
Re: AGM MK96 spacer
Pm me your phone number and help you through it..... Im not 100 percent sure on this rifle but i would think there should be a set screw that holds the hop up unit and inner barrel in place and it should screw in through the outer barrel and into the hop up? ( very small screw) like i said though im not 100 percent on that but if i didnt have one i would add it if it were my rifle
tm l96 aws
kwa sr-12
kwa sr-5
echo 1 asr
de m81
kwa g17
kwa sr-12
kwa sr-5
echo 1 asr
de m81
kwa g17
Re: AGM MK96 spacer
Hey sorry i figured it out already
. Yeah after going through the end of the barrel didnt work i decided that i would take the gun apart slowly and see what i could do. And like u said several tiny screws later i was able to take the inner barrel and the hop up unit out as one piece for the outer barrel. From there it was easy to fix the spacer, then i just put it all back together. But thanks for the offer and also thanks for the advice!
OP: Phantom Hawk
SGC
OP: Vietnam Patrol
OP: Decisive Force
OP: Phantom Hawk
SGC
OP: Vietnam Patrol
OP: Decisive Force
