Hey guys.
some of my high cap mags are not working properly. They won't feed the ammo from one side to the other. when I tern the "crank thing" on the bottom it feels like it is all the way wound but yet its not. should I just get some new mags? Or is it an easy fix?
If anyone can help that would be most appreciated.
Jay
M4 mag problem.
M4 mag problem.
It is not the camo, or the gun that make a good player. its the skill, and team work from the man behind those things.
Re: M4 mag problem.
Hicaps are always an easy fix, meet me at the next game and I'll show you how.
Re: M4 mag problem.
Your coil spring inside could be broken. Google around a bit for some hicap disassembly guides and it shouldn't be too hard to diagnose.
Re: M4 mag problem.
More then likely the coil spring isn't attached. It is an easy fix, you can look up how the spring is supposed to be attached thats how I fixed mine. But to avoid these problems ditch hi-caps completely. I only run one high-cap and thats the one including with my gun, I love my midcaps.
[img width=550 height=100]http://img18.imageshack.us/img18/4259/signature0p.png[/img]
Re: M4 mag problem.
Midcaps have different technical problems, but just as many...
Re: M4 mag problem.
Yeah but the mags are much more simpler making easy fixes.Dominum wrote: Midcaps have different technical problems, but just as many...
Re: M4 mag problem.
I like midcaps I just don't have any rightnow.
