want (in order of need) can add cash:
Systema PTW MAX gearbox (MUST be a max box)
M81 woodland COMBAT set (must be allwin and M-L)
FCC or PTS PMAGs
Systema Steel cylinder
What I have for sale:
The gearbox, mosfet, and motor, is perfect for if you want to start piecing together a ptw style rifle.
$60 - Celcius CTW gearbox. This is not the CNC'd gearbox. It has also been fitted with a systema sector gear to better mesh with OEM systema, FCC, and velocity cylinders. Will also come with the OEM ceclius sector gear. Will come with the selector switch and parts. Will NOT come with the FCC speed trigger but the OEM celcius trigger.
$60 - G&D motor. 100% stock, bought it being told it was a systema 480 motor and got scammed. This has not been used in game by me just hooked up to see if it would actually work. It can pull a M130 but not an M165. Did not have any other cylinder to test with. This would work great as a back up motor in case your systema 490 goes down. Pinion gear is in great shape.
$40 - Celcius mosfet. This works great. I just prefer systema stuff. Would work great as a cheap backup. Has been converted to deans. Once again got it thinking it was PTW. I guess I am way to trusting huh...
$120 - FCC velocity cylinder. It is the M130 version. Again it came broken when i bought it. The piston rack pickup tooth is wore down to the point of the sector gear cannot engage it. It is a $2 part on RSOV. Easy fix and it does work when I installed a OEM systema piston unit in there to test. If you want take $2 off to get the part you need.
$80 - Systema steel outer barrel.
Overview:
Not pictured but for sale ( I WILL NOT take payment till I get pictures up to prove that I actually own these):
$50 - STTS hop up 1st version, the blue one. This allows your PTW to have hop up that is adjustable from the ejection port and has two points of contact vs the OEM one point of contact. This leads to more stable shots and better accuracy.
$300 - Real LBT 6094K in AOR1. pics up later
$300 - Pantac CT RAV. Comes with pouches. This is the $500 vest http://www.redwolfairsoft.com/redwolf/a ... G_font.htm. Will include most of the pouches.
