-No trades whatsoever!
-I am only able to ship Thursdays, so you'll have to take that into account.
-All items are sold as is!
-All items are OBO. Feel free to make an offer!
I'll start with these two:
Upped TM OD M14
Externally, nothing special. Internally, nearly everything has been replaced.
- Guarder Steel semi auto latch
- Guarder enhanced anti reversal latch
- Prometheus Double Torque Gears
- Prometheus 6.03 tight bore barrel
- MS135SP spring
- Upgraded cylinder head and piston head
- Metal gear bushings
- MOSFET with active breaking to prevent over cycling of the gears
- Systema Magnum Motor
I don't recall the brand on some of the stuff, but just the gun, barrel, gears and motor alone is better than $650. You should note, the gun has been modified for semi auto use only! Now, the only problem with the gun is one of the motor wires: as of now, it's being held in place with electrical tape but the connector needs to be replaced or just soldered in place. I'm going to ask $350 shipped.
NIB G&G PM5-A5
Like I said, brand new. Test fired, less than a full mag. Since I'm selling the M14, I have no need for this as it was intended to be the backup for the M14. Will come with everything included in the box: battery, claw mount and such. I'm even going to include the battery (http://www.airsoftatlanta.com/11-1v-100 ... /47991.htm) I bought for it since I have no use for it. Asking $200 shipped.
