question on outer barrel
MaTaX91
Post by MaTaX91 » Wed Jan 02, 2013 8:11 pm
So I have an Echo 1 Stag Arms Licensed AR15 style airsoft gun, it has an outer barrel that looks to be about 14.5 inches or so, I know the inner is somewhere around 350mm. It has 6in RIS.
Here is the barrel I'm considering getting...
http://www.airsoftgi.com/product_info.p ... ts_id=7924
Thing is it doesn't have a delta ring (no prob) or the other end that the RIS fits into (problem)
I don't know how this works. I want to replace it so I have a threaded flash hider (tired of playing with that big ugly orange one) but I'm a little confused on if I can get this and it be compatible with my setup and RIS system.
Can anyone help me out?
Mad Magpul
I like this place!
I like this place!
Re: question on outer barrel
Post by Mad Magpul » Wed Jan 02, 2013 8:14 pm
You can take the orange flashider off.......
Team V.S.A.M
Armory:
KWA KMP9
Magpul Masada
Custom Daniel Defense DMR
MaTaX91
Post by MaTaX91 » Wed Jan 02, 2013 8:19 pm
tried man, it's like glued or locktighted on, could not get it off without really messing up my outer barrel
Post by Star_folder » Wed Jan 02, 2013 8:25 pm
You can get it off, I promise. Check for screws on the flash hider.
MaTaX91
Post by MaTaX91 » Wed Jan 02, 2013 8:27 pm
there was one set screw that I took out and still no luck
Mad Magpul
I like this place!
I like this place!
Post by Mad Magpul » Wed Jan 02, 2013 8:32 pm
There should be a little tiny hex screw at the base of the flashider (usually on the under side of the barrel) take it out if it isn't already. Then soak the WHOLE flashider and even a little of the barrel in boiling water for around 10 mins. Then get pliars and quickly twist it off before it cools. If it doesn't work stick it back in for about 5 mins and repeat the steps. This is what I do for all of my orange flashiders.
Team V.S.A.M
Armory:
KWA KMP9
Magpul Masada
MaTaX91
Post by MaTaX91 » Wed Jan 02, 2013 8:34 pm
that's a new trick I will try that thanks
Mad Magpul
I like this place!
I like this place!
Post by Mad Magpul » Wed Jan 02, 2013 8:36 pm
No problem. These things are always pesky just be patient with it. They eventually always come off.
Team V.S.A.M
Armory:
KWA KMP9
Magpul Masada
MaTaX91
Post by MaTaX91 » Wed Jan 02, 2013 8:55 pm
cool the boiling water trick worked, thanks! Crisis averted!
Mad Magpul
I like this place!
I like this place!
Post by Mad Magpul » Wed Jan 02, 2013 9:20 pm
No problem. Glad it worked out.
Team V.S.A.M
Armory:
KWA KMP9
Magpul Masada
Jeremy314
Post by Jeremy314 » Thu Jan 03, 2013 8:47 am
To answer your other question about the "other end" of the barrel assembly, you need to have a roll pin punch set, a (preferably) rubber headed hammer (I use this one) and tap out the small roll pins on the bottom of the front sight post, take it off and put it on the new barrel.
A vid that can help you out a bit: http://www.youtube.com/watch?v=uMG3IP2KH6g
You don't have to worry about removing the one that holds the mock gas tube on, unless you just don't want it there anymore, but the front post will take some elbow grease to get off so just be patient with it.
MaTaX91
Post by MaTaX91 » Thu Jan 03, 2013 9:44 pm
okay cool, I'll keep that video in mind.
So on a curiosity note how would I make the front end of my gun look more like this one?
http://www.airsoftgi.com/product_info.p ... s_id=11002
With the way my gun is now I'm thinking it's probably not possible without some serious front end conversion.
Mad Magpul
I like this place!
I like this place!
Post by Mad Magpul » Thu Jan 03, 2013 11:13 pm
You would have to get a longer outer barrel with no triangle sight and a different rail system.
Team V.S.A.M
Armory:
KWA KMP9
Magpul Masada
Jeremy314
Post by Jeremy314 » Fri Jan 04, 2013 7:31 am
Yep, exactly what Magpul said. You'd have to get a free float rail system like one of these:
JG SR type rail system
Daniel Defense Lite rail
Daniel Defense MK18 rail
And you might want to look into getting a mock gas block too.
MaTaX91
Post by MaTaX91 » Fri Jan 04, 2013 7:20 pm
Okay, okay.
So if I got this gas block here...
http://www.airsoftgi.com/product_info.p ... ts_id=6674
With this rail system here...
http://www.airsoftgi.com/product_info.p ... ts_id=3537
Would I still need to get a new outer barrel if my current set up looks like this one...
http://www.airsoftgi.com/product_info.p ... s_id=10155
(That's pretty much the exact gun I have except it didn't come with the crane stock)
I can't just use a punch to punch out the triangle sights pins and remove it and keep my current outer barrel?
BTW thanks so much for all this info, you guys are a wealth of amazing knowledge!
