Real Sword type 97 and 97b
Haze
I like this place!
I like this place!
Post by Haze » Fri May 18, 2012 3:46 pm
So I've been saving for my l96 sniper project and over time I've become less and less interested with sniping. I just want to know if anyone have any knowledge about these guns. Anything will be helpful.
Team Insert Name Here - I.N.H CO
A&K M249|H&K G36CV
OP: Crisis In Dunundistan II
OP: Flash Heaven
OP: Second Sun
Escue Airsoft Mini-games
Auguest 4th Airfarm games
Avenger
Re: Real Sword type 97 and 97b
Post by Avenger » Fri May 18, 2012 3:50 pm
Real Sword is as close to PTW as you can get with commie weapons.
Post by SteevoLS » Fri May 18, 2012 3:59 pm
Umm... only if you're defining a PTW as 1:1 dimensions.
Haze: They're good CQB guns. They're weird guns. They're well made guns. They're not terribly expensive.
Not much more to say. :P
Avenger
Post by Avenger » Fri May 18, 2012 4:51 pm
SteevoLS wrote:Umm... only if you're defining a PTW as 1:1 dimensions.
Isn't 1:1 and not dry firing and compatability issues the only thing different about PTWs.
Even so, a RS Type 56 is as close as you can get to an AK PTW isn't it?
Echo1 Operator
Echo1 Rep
Echo1 Rep
Post by Echo1 Operator » Fri May 18, 2012 5:00 pm
looooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooool
Post by SteevoLS » Fri May 18, 2012 5:11 pm
PTW...
- Planetary gears (tiny little gearbox about the size of a deck of cards). Extremely high torque and extremely reliable.
- Built in MOSFET array (the only real weak point anymore)
- 1:1 dimensions, 1:1 magazine dimensions, 1:1 weight vs matching model in real steel, no dry firing, etc
The only way to compare a RealSword AK to a PTW is dimensions when compared to real counterparts. The receiver is a hair shorter than other brands; otherwise it's no different than any other high end AK like a LCT or VFC.
Haze
I like this place!
I like this place!
Post by Haze » Fri May 18, 2012 9:55 pm
Thanks SteevoLS. Can you compare the systema ptws to the celcius ptws?
A&K M249|H&K G36CV
OP: Flash Heaven
OP: Second Sun
Post by SteevoLS » Sat May 19, 2012 8:07 am
A brand new version of the CTW just came out within the last month or two, but I haven't heard anything about them in terms of reliability.
CTWs are just like PTWs, but not as reliable. Imagine you had a PTW, but you had to worry about pistons stripping, gears stripping, etc. CTWs have something along the lines of a 70% lemon rate. The 2nd and 3rd versions are not 100% PTW clones, meaning if it does break you have to use CTW parts instead of OEM or aftermarket PTW parts to fix it.
Unless you can find one used for a really good price (if it has worked long enough to be sold as a used gun, it probably isn't a lemon) I wouldn't buy one. I would not pay the retail price, considering that I can go on systema-ptw.com and buy a PTW for under a grand any day of the week.
Haze
I like this place!
I like this place!
Post by Haze » Sat May 19, 2012 6:42 pm
okay, Thanks.
A&K M249|H&K G36CV
OP: Flash Heaven
OP: Second Sun
