Setting up my chest rig...
I recently purchased an Eagle LE MOLLE chest rig. It contains a 15x4 MOLLE grid.
My current plan is, from right to left...
Maxpedition Monkey Combat Admin pouch (4x4)
Condor triple-stack 6-mag pouch (6x4)
5.11 radio pouch (2x4)
Condor utility pouch (3x4)
That should fill it up completely. Anybody have any recommendations for alternative pouches, or critiques of my choices?
Esteban
Re: Setting up my chest rig...
Is that the AK mag pouch?
No, stacked M4.
[img width=300 height=300]http://www.armysurplusworld.com/custom/ ... tacker.jpg[/img]
Esteban
Oh okay. I was confused by the "triple stack" part.
Looks good to me. Are you getting it in black, tan, or OD? I'm really liking my chest rig. It's very lightweight for when you have to run at/from the enemy
Base rig is in Eagle Industries Khaki. The pouches will be in khaki, tan, coyote brown, etc. I don't really care if they all match perfectly.
Maybe add a roly poly and/or pistol mag pouch ( if you run a pistol ). Other than that sounds solid.
[img width=500 height=100]http://i487.photobucket.com/albums/rr23 ... ckcopy.jpg[/img]
He runs an AEP so he could stick it in the admin pouch. Sounds like a solid set up Steevo.
A Fact of Life: After Monday and Tuesday even the calendar says W T F.....
Severed: if the back up to the back up back up rifle doesn't make people drool, you = fail
Airsoft Vet.
Airsoft Vet.
As Inked said, I run a TM G18C AEP. The short mags are very small, and would fit fine in the admin pouch, or anywhere else you could fit something about as big as 2 packs of gum.
I've already got a belt, Safariland, and roll-up dump ouch so I should be set in that regard.
Sounds good but you did forget one of the most important things, hydration.
Big Bird [Rifleman]
SWC, Special Warfare Command
"Adapt - Evade - Overcome"
Villid
sounds like a good setup. pretty much th3e same setup i use, and its been great so far. only thing would be if you had a panel on yoru back, and wanted to use that.
Esteban
I remember him saying he'll attach a hydration pack to the back.
I'm going to use a completely separate hydration backpack.Big Bird wrote: Sounds good but you did forget one of the most important things, hydration.
- Joshua
- Here for a while...
Depending on the way you reload, I have the most mag pouchs on my left side (I reload with my left hand) where they are easy to reach, as well as the dump pouch if you get one on that side as well, everything else not used enough goes on the right or in the admin pouch.
IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE
I'll definitely shuffle things around to see what works best for me.
- Joshua
It took me 2-3 games to find the best fit.SteevoLS wrote: I'll definitely shuffle things around to see what works best for me.
